pulley size and boost
Old Jan 22, 2006 | 09:36 PM
TwoFast's Avatar
Default pulley size and boost
how much smaller must your pulley get in order to see another 1 psi of boost?
I'm wanting to get a 2.9" pulley for my sidemount and was wondering if I'll see over 5psi. I'm currently seeing only about 3psi and want to bump it up to about 6-7psi with a meth kit. A week ago I was barely creeping away from a rc/sb 4.8l silverado with a cam, intake and slight tuning and exhaust. I want to flat out out run him next time. BTW: How do you measure the size of the pulley, is it from outer lip to outer lip or do you measure from side to side where the belt rides on the pulley? Thanks
Old Jan 22, 2006 | 09:46 PM
bud8fan's Avatar
allen nelson has his pulleys on sale right now..call him up or go to ls1truck and ask him this question..he will have an answer for ya...or just pm him here...he is farmtruc...
Old Jan 23, 2006 | 12:48 AM
2500HD6.0's Avatar
I would do the meth kit with your set up before you put on a smaller pullley then you can keep your intake temp down and you can add more timeing. When I did mine it added alot of power. You really do need to do a meth kit with that charger. They put out tons of heat and if you do a smaller pulley with out the meth you might burn you motor up.
Old Jan 23, 2006 | 12:50 AM
TwoFast's Avatar
I'm going to install the meth with the smaller pulley. About how much boost do you think I'll make with the 2.9 pulley on my 5.3l since I'm only getting 3 psi with the stock pulley?
Old Jan 23, 2006 | 12:51 AM
2500HD6.0's Avatar
Allen only carries radix pulley's and they won't work with the sidemount
Old Jan 23, 2006 | 08:55 PM
2500HD6.0's Avatar
I'm not sure you should do a search to find out how big your stock pulley is I think mine is 3.0 but it's for a 6.0 (it takes a smaller pulley to make boost on a bigger motor) I think yours might be 3.3 so if you run a 2.9 you should make around 7 psi.
Old Jan 24, 2006 | 06:58 AM
Fogle07's Avatar
from what ive read they dont recommend changing pulleys on the sidemounts right? maybe blownchevy will chime in
Old Jan 24, 2006 | 12:38 PM
Av04's Avatar
Did you ever measure your stock pulley size?I have a 2.9" or so that gave me 6-7 psi on a sidemount (I Sold it,too noisy for me).BUT it hits the houssing and you have to grind the housing a little.BIG power increase.The stock pulley was lame
Old Jan 24, 2006 | 04:31 PM
2500HD6.0's Avatar
you put a 2.75 on yours and made 10psi. any problems?
Old Jan 24, 2006 | 04:33 PM
TwoFast's Avatar
I believe my stock pulley is a 3.3". So I need to grind a little on the blower snout to get the pulley to slide over it?
