pulled the trigger trick stg 3 etc.
Old May 23, 2013 | 08:11 PM
roland1's Avatar
Default pulled the trigger trick stg 3 etc.
yep. this week I ordered the following for my 2013 sierra rcsb 5.3 vvt/FF 4x4...
trick stage 3 kit -76mm/ .96ar journal bearing magnum turbo.
devils own meth kit
fuel injector connection 70lb injectors
spintech 6000 muffler 3.5" in/out
PLX 100 gauge & Bosch wideband o2.
tune is booked for Monday june 17. so needless to say that weekend is gonna be a busy time installing everything.
what kinda power do you think i can "safely" squeeze out of this thing?
any tips or advice is more than welcome!
im excited! no more 15 second passes!
Old May 23, 2013 | 08:20 PM
fortplainman's Avatar
check out this thread, its only on the 70mm but he is putting down 416hp and 444tq on 8# of boost and is his daily driver. anything ive seen with trick kits everyone loves them.
https://www.performancetrucks.net/fo...tricks-501958/
Old May 23, 2013 | 08:27 PM
Choda's Avatar
A weekend is a good amount of time for your first time. Set goals per day.
Friday all stock stuff off and start install
Sat finish installing the kit and fire it up
Sun final tweaks
Is your tuner sending u a begin boost tune so u can baby it around? If not it will throw 4 or 5 codes and go into limp mode. Mine did.
Call me anytime u have any question. I can prolly help w any type of question or hiccup u might run into because I had the same thing. Rick is only a txt or call away too.
Have spark plugs, vac hose, 5/8 heater hose, fittings for the water hoses, vacuum lines, Exhaust wrap, paint, 2.5-3.5 house clamps to hold the exhaust wrap, check valve for the pcv.
Read the multiple build threads on here
Good luck man
Old May 23, 2013 | 08:41 PM
Byrdman11's Avatar
I second Choda ideas
Old May 23, 2013 | 09:26 PM
Choda's Avatar
I do not have meth either so ur on your own w that. I would also recommend a catch can. My intake was oil soaked. I just installed the mike Norris can
Old May 24, 2013 | 10:29 PM
roland1's Avatar
Do you have hp tuners or something to have uploaded the tune? sounds like a good idea but I don't know how I would upload a tune without hp tuners or efi live. the tuner is gonna be using efi live.
Im gonna get plugs for sure. Gotta look up what everyone is running.
Obviously I don't have the instructions yet but im curious, why would I need heater hose and fittings for water hoses? And why do I need paint? lol pardon me but im a "why?" kinda guy, like to know why this why that!
Good luck man
Solid advice none the less though man, thanks.
And yes catch can too is gonna be ordered soon. gotta read into best way to install one for a boosted motor.
Y'all reckon I can put down 600 rwhp with this or no?
Old May 25, 2013 | 11:16 AM
Denali08's Avatar
What are u doing with fuel pump?
I doubt you will hit 600rwhp. That turbo is rated 700hp (flywheel).
Also, isn't the T76 a trickperf stage-4 kit?
I have stage-4 kit with T76 and nubmers are in my signature @18psi of boost.
Old May 25, 2013 | 04:31 PM
TrickTurbo's Avatar
Truck Sponsor
Stage 3 is a JB 76
Stage 4 is a BB 76
Either kit can be upgraded to a precision 76/75.
Your numbers seem low at 18 psi. ??? I would expect 650range with your kit and that psi. If all things are dialed in.
I have had a customer hit 600with a 70 before.
Old May 25, 2013 | 06:14 PM
Choda's Avatar
Ask ur tuner now about how he is going to tune it. Is he local to u or all over the web and email tunes?
5/8 heater hose is for when u move your stock water/heater hoses away from the turbo location.
Paint is silicone paint for after u wrap your pipes
I run tr6 NGk plugs at 34 thou I beileve
Old May 25, 2013 | 08:02 PM
franko98's Avatar
Who is tuning ur truck ?? I should see my stage 2 kit to in the middle of June also goin on a 2013
