PT88 vs. TC78
Old Jan 17, 2011 | 02:43 PM
DoubleTrouble's Avatar
Originally Posted by Atomic
The PT88 is actually pretty easy to control with your foot since boost takes a while to come on whereas the smaller turbo would spool quicker. I will have my pt88 on my 5.3 here in a few days so Ill let you know how that goes...
Alright thanks.. I'll be waiting for results
Originally Posted by Daryn
id go for the smaller turbo for DD power comes on quick and when you need it
Originally Posted by cjg454ss
i agree. you really need to look at the compressor map of the turbo. bigger isnt always better. the pt88 is laggy, i had one. imo a gts76mm would be the biggest id put on a truck. it will spool much faster and support 750rwhp.
if your going over 750rwhp.... get a pt88, if not then dont get it but a 750 REAR wheel hp truck is a serious setup.
additionally,, once you start getting up that high in hp the T4 flange becomes an issue. A front mount 400cu motor with a pt88 is a horrible combination.
I understand why yall are saying get a smaller turbo since this is a DD truck(for now). I checked out the compressor map of a PT88 and compared to a 364 ci motor it looks to be a good match staying in the 85% efficiency range while not having any turbo surge. Then to double check that, I called Precision Turbos and told them what my goals were to see which turbo they would recommend. Of course if was the brand new $3390 ball bearing unit out.. but it was an 89mm exh/88mm comp. However, they did say a PT88-47 would be sufficient for my future goals(single digits).
Also, I know that the T4 flange will be hurting performance on larger cubed motors but I'm most likely going to stay with a 370 ci. But doesn't flaco have a PT88-47 on a 427 cubed motor?? Or is he running the T6 version?? I saw him run a 9.1x @ 15x before.
Old Jan 17, 2011 | 04:02 PM
Atomic's Avatar
I have a gauge for that
Where did you find a compressor map for the PT88? I never could find one.
Old Jan 17, 2011 | 04:12 PM
I can't remember off hand, but I'll see if I can dig it up by going through my history.
Old Jan 17, 2011 | 08:19 PM
Banned
thats kinda funny because 2 years about i had a pt88 on a 365cu ls1 and i kept breaking the journal bearing and precision said that the turbo was seeing excessive backpressure and that i needed a larger hot side for the cube motor. it was nothing crazy either, stock 317 heads and 20psi of boost reving to 6500rpm of so.
precision said the pt88 was built for the grand national guys for a particular class. it likes less cubes and the hot side a/r is limited to .96 i believe.
Old Jan 17, 2011 | 09:26 PM
Not trying to argue with what you're saying.. but I'm getting a little confused.
In your first post you're saying that the PT88 will be too big and have too much lag for a Lq4.
In your second post you're saying the PT88 likes less cubes than 36x ci.
If the Pt88 in fact likes less cubes would it spool fine on a Lq4?? If it makes a difference I'm looking into the PT8847H which has a GT4788 CHRA bearing and is rated to 1400HP. It's supposed to spool faster than the standard PT88.
Old Jan 17, 2011 | 09:38 PM
My old set up was a TC-78 .96 a/r .. Built 6.0 9.5 comp and WCCH heads...
It spooled to quick and choked up top... Boost was instant , but to violent in my opinion.
I now run a GT91 T-6 set up on the same engine, alot more control and pulls like no other!
Night and day difference.
I would say the PT-88 over the TC-78, but would go T-6 if possible... I wish I would of done that from the start..
Old Jan 17, 2011 | 09:43 PM
Precision also said that one day if the T4 was holding me back I could upgrade the exhaust housing to a T6 style flange but they wouldn't recomment anything bigger than a 370 cu in.
Old Jan 18, 2011 | 06:56 AM
Banned
yea the pt88 would be laggy. here is why, its going on a truck. the turbo was intended for grandnation v6s(according to precision), leaving on a transbreak and 2 step. much different than a street truck.
when you see a dyno pull with the torque higher than the horsepower...you know the turbo was choking. an example was with my pt88, i make 800rwhp and 820rwtq. thats a T4 flange on 22psi. on a t6 S91, 988rwhp, 850rwtq on 17psi.
if turbos have low backpressure they will really start to shine uptop. a choked turbo will go flat. my setup went flat and the new setup pulls an extra 200hp. thats a lot more power for only 3mm more tubine and less boost.
additionaly, the physical size of the pt88 is little compared to a t6 S series turbo. personally i went through 3 pt88s and wouldnt put another on my lawnmower. there are much better turbos to chose from, a T6 S76 will blow a t4 pt88 out of the water, but some people just want to say "its an 88mm"
Old Jan 18, 2011 | 07:16 AM
smokeshow's Avatar
Mod with training wheels
We've had our arguments, but I definitely agree with all of that...
Old Jan 18, 2011 | 08:10 AM
Banned
arguments? i call them constructive conversation
