Progressive Meth settings, post them up
Old Jan 5, 2013 | 10:02 PM
black4.8's Avatar
What happened to your devils own controllers? That's what I'm using
don't want to totally run devils own in the ground. they have great pumps and nozzles. have actually purchased nozzles after the issues. customer service was great w/ the controller replacement. they badly need to fix there problems w/ controllers tho. controller commands pump to come on for no reason. w/o ignition even on. not good when you come out of gas station and hear your meth pump filling your intercooler w/ methanol. something shorts out in the controller. the last time i took the controller apart myself and the wires weren't on the right terminals . whoever builds there controllers must be smoking some good stuff. i've heard of others having similar problems. the old controllers used the + to control the pump. the new ones use resistance in the ground. the old controllers might be ok.
Old Jan 6, 2013 | 10:03 PM
BlackGMC's Avatar
Resident Retard
Interesting, seems like alot of guys are turning the meth on at lower levels. Thanks for the examples!
Old Jan 7, 2013 | 08:48 AM
casper02's Avatar
Good info what about using the devils own switch instead of the controller?.
Old Jan 7, 2013 | 09:01 AM
nonnieselman's Avatar
Im using a older Devils Own Controller. 2008 i think it was.
I use to have mine coming on at 2psi and full at 10psi when i had the smaller injectors.
Now it starts at 5psi and full at 15 psi. So its not spraying until i get on it. Devils own 14, 10, and 7 nozzle
3 gallons lasted me 6 weeks but i didnt run it hard.
Oobray
Jun 13, 2022 03:38 AM
SLOPONY
20
Oct 18, 2016 06:05 AM
rednekferlife101
32
Jan 8, 2016 10:42 PM
GM1697
Oct 8, 2015 11:06 AM
Sexyrado327
Aug 2, 2015 04:08 PM
