Procharger Stage 2 bracket...any one replaced their tensioner with a HD tensioner?
I've done everything from Procharger on their Stage 2 bracket system that they have recommended....even put a 8.25" crank pulley with the 8 rib system and still losing boost (its up from 8 psi to 11 psi) and having some belt dust....I should be closer to 18-20 psi from estimate from Procharger with my F1x.
So, I'm looking at replacing their tensioner with a HD tensioner that will move and apply more tension in the upper rpm and maybe relocating a few idler pulleys for more crank pulley wrap and more head unit pulley wrap. The House of Boost kit uses a 38510 Gates tensioner...but it's counterclockwise in rotation tension. I'm needing clockwise in the same design.
Any one have this problem and put a HD tensioner on it?
02 w/ lowest mileage 2800
Try dayco 89442, that’s clockwise rotation with a 39.25mm wide pulley. I use dayco 89440 on my 12 rib setup, but that is counter clockwise rotation. I think no matter what your going to have a hard time spinning that f1x on an 8 rib belt.
Not saying he was wrong but in the current configuration...it ain't happening. I made more boost with my D1SC but 11 psi on the F1x is a different animal.
I made a list of 46mm Gates pulleys..I'll check that one out though.
What bracket are you using?
I tried to do a 12 rib but Nathan at Procharger assured me that the 8 rib would be just fine....
I tried a gates tensioner first, but it kept twisting and throwing the belt. I swapped to the dayco and everything works as it should.
Out of curiosity, what intercooler are you running and how large is your piping?
Piping and intercooler are a bit small which will only compound the slipping problem. So will an air filter that is too small or clogged. I would use a cog drive as a last resort. They can be just as much a pain to set up correctly and get the belts to stay on or not snap.
