procharger pulley 6 rib
Old Nov 3, 2009 | 03:12 AM
Most Hated's Avatar
Default procharger pulley 6 rib
wat pulley can i run with out issues ? , cuz my 3.4 gives me 10lbs and drops slowly , alot of black dust under the pulley, too much slip
Old Nov 3, 2009 | 01:29 PM
the_reaper's Avatar
Well IMHO you need to get rid of the 6 rib setup, I have read alot of people who seem to have isssues with running more than 6lbs of boost with a 6 rib setup. I would talk to bob at EPP or procharger, I know that they make a system that will give you a 6 rib for your normal acc and a 12 rib for the procharger, this is what I am running on my set up. I am pretty sure they do one for the LS series motors. Just my .5 cents. here is a picture of my current setup. its not a LS series motor b ut you get the picture. this is not with the A/C option but they also have one that retains your current A/C
Old Nov 3, 2009 | 02:10 PM
sharpshooter's Avatar
man I make 11# @ 6000 rpms with my 4.25" pulley but I have a different cam and FMIC
Does your boost gauge climb with your rpm's or does it level off? If it stops climbing I'd say it is slipping.
Maybe your pulley is actually too small.[not enough belt wrap]
Old Nov 3, 2009 | 02:15 PM
Also what brand belt are you running and is it the right length?
Old Nov 4, 2009 | 12:19 AM
Blown06's Avatar
8 Second Truck Club
Ya'll are doing something wrong. I see 14 lbs with my 6-rib.
Old Nov 4, 2009 | 01:39 AM
Most Hated's Avatar
i put the 3.6 today got 13lbs out of it
Old Nov 4, 2009 | 01:41 AM
Most Hated's Avatar
wat pulley do you have ?
Old Nov 5, 2009 | 02:12 AM
stoffer's Avatar
I paid my buck-o-five
I'm making 15# on a 6 rib belt drive and I've added an additional idler pulley, I up the boost anymore, I'm just going to go cogged...
Old Nov 5, 2009 | 02:19 AM
stoffer's Avatar
I'm also running a better air inlet setup and that helps alot
Old Nov 5, 2009 | 02:28 AM
Most Hated's Avatar
pics..........
