procharger filter mod
Old 07-01-2012, 09:43 AM
  #31
Laid Back
Beatdown Z's Avatar
True true, i was feeling lazy so I just ordered it haha
Old 07-01-2012, 06:35 PM
  #32
Pc2000trk's Avatar
Originally Posted by Trevor F
so how would this work with a tune thats set for 8 psi. if you see more boost this way wouldnt you need another tune for it? im still learning lol
It should correct fuel on 2lbs that's not much
Old 07-01-2012, 07:26 PM
  #33
02'Z71ONDUBZ''s Avatar
That's not necessarily true, it depends on how the tuner set things up.
Old 07-01-2012, 08:14 PM
  #34
03sierraslt's Avatar
Exactly, thats a risky assumption.
Old 07-01-2012, 09:11 PM
  #35
idahoblkss's Avatar
I got a a fuel pressure regulator that is boost referance so mine corrects automatically.
Old 07-02-2012, 09:18 PM
  #36
Pc2000trk's Avatar
No I hear ya but Ive read his setup and knew it had a boost reference regulator on it same as mine - so without a lengthy write I was answering short and sweet .. but with that setup and the correct fuel tables in place it should be fine is what I shoulda said lol
Old 07-17-2012, 01:49 PM
  #37
AndysC3's Avatar
Mine came with the Proflow surge valve, which recirculates the air to the inlet of the Procharger. Would I still be able to do this?
Old 07-17-2012, 01:56 PM
  #38
ak2007r6's Avatar
When I am at the track I remove the filter and then just unhook that whole tube from the back of the Procharger and push it out of the way. That way the surge valve can still dump back into that tube but there is nothing on the back of the Procharger that will hinder it getting air.
Wish I had a pic to show ya.
*edit.
It was a noticeable gain for me though. I averaged picking up between 1-2/10th's in a few runs
Old 07-17-2012, 01:58 PM
  #39
AndysC3's Avatar
OK, thanks
Old 07-17-2012, 02:00 PM
  #40
idahoblkss's Avatar
Originally Posted by AndysC3
OK, thanks
you have the little black valve that has the butterfly valve in it?
Quick Reply: procharger filter mod
