Procharger on 6.2 (Runs like crap) HELP
Old 08-29-2015, 05:20 PM
JCW
JCW's Avatar
Default Procharger on 6.2 (Runs like crap) HELP
First off I have ran searches and tried several different solutions but still runs like crap.
So I have 2011 Sierra 6.2L 2wd flex fuel with P1 Procharger, 8lb pulley, Corsa Sport, removed 3rd cat, 89lb Fast injectors and KHP tune.
I did the install myself and drove to KHP to get injectors and then tuned. Now first off truck will hit 8-8.5lbs of boost but surges at idle and acceleration. But KHP did tune in first gear and let out each time at shift so we didn't feel surging, but I did feel surging at idle and he says that's normal. (Its a 500-600rpm surge, that's not normal) On the way home I floored it 1st through 3rd and noticed something didn't feel right and as I let out the SERVICE TRACTION CONTROL - SERVICE STABITRAK - REDUCED ENGINE POWER LIGHTS came on. I limped to side of road and turned off. Waited 30 sec and started up, truck was no longer in limp mode and I drove home. SES light was on and so I pulled codes with scanner. P0120 (throttle body circuit malfunction) I replaced TPS and issue still remains. Surging at idle, surging upon acceleration and then when I floor it for a few seconds the dreaded SERVICE TRACTION CONTROL - SERVICE STABITRAK - REDUCED ENGINE POWER LIGHTS come on with new codes P0068 (MAP/MAF sensor pressure) P0108 (manifold baro pressure). So I check all my PCV and vacuum lines to make sure all are tight and installed according to the Procharger manual and all seem fine. I decided to clean throttle body and Mass air sensor and take for test drive...same scenario everytime. More surging at idle, surging on acceleration, codes etc...It has now done it 4 times.
I have called KHP but he seems to get defensive immediately when all I am trying to do is seek advice and get to the bottom of this i'm not pointing fingers. And he claims his tuning is not the issue. I have no clue at this point....ANY IDEAS?
Old 08-29-2015, 07:24 PM
bud8fan's Avatar
my '11 did the same thing with the traction/stabilitrac notice and limp mode....there is a fix for it on a thread in here so they can tune it out.
Old 08-29-2015, 09:54 PM
JCW
JCW's Avatar
Do you have an idea what it was that fixed yours?
Old 08-30-2015, 09:17 AM
bud8fan's Avatar
allen changed my pcm and my throttle body out . I still get the service tc/st message but it does not go into limp mode ..I did see the fix in a thread here and gave it to him but have not been back up to the shop with this truck to tune it out...ill look and see if I can find it again in a thread here.
Old 08-30-2015, 05:44 PM
JCW
JCW's Avatar
I've been reading about guys swapping out throttle bodies for the fix. Some it works others say no change. I did replace TPS but did nothing. I guess I'll give it a shot....might as well upgrade to LS3 or LS7 throttle body while at it.
Old 08-31-2015, 04:27 PM
bud8fan's Avatar
I was hoping someone with the info would chime in with the answer because I cant find it either...good luck.
Old 08-31-2015, 04:45 PM
Formerly ScreamingL
George C....'s Avatar
Tune related find another tuner
Old 08-31-2015, 08:25 PM
1-87 chevy's Avatar
^^^^ iam with him
get yourself a different tuner before you drop money on parts you don't need.
Old 09-03-2015, 10:55 PM
JCW
JCW's Avatar
Who do you guys recommend in the Houston area???
Old 09-04-2015, 09:06 AM
Registered User
fondupot's Avatar
Go on the ProCharger website and find a dealer in your area and call around to see who has the most experience with tuning those. That's how I found a local shop who I am going to consider doing my install and dyno tune.
Quick Reply: Procharger on 6.2 (Runs like crap) HELP
