Prefered Meth Injection Kits
Old Oct 11, 2011 | 09:39 PM
  #31
kbracing96's Avatar
Originally Posted by Swerve7rpm2000
Bringing this thread back from the dead, im planning on making a DIY meth kit.... It makes perfect sense to put the meth nozzle before the iat sensor but i belive the one i have is not able to get wet! Does anyone ever mount it after the sensor? What size jets are guys running with 20+ boost and 1000-1200 hp?
Stock48 is the only one I know at that power level and using meth. He had 3 650ml nozzle which are about the same as m15 nozzles. But he was running strait meth and NEEDED the extra fuel from them! lol
Old Oct 11, 2011 | 10:10 PM
  #32
SuperSilverado53's Avatar
I curious If spraying meth/water in the engine. Cause parts will rust inside the engine?? Is it a cool way to make more power ?? if it fail and the meth kit doesnt work but tune is still set for one, it can blow engine ?? if they had a lot of timing added because of the meth kit, an then the meth pump fail is it will be hurtful the engine ??
Old Oct 12, 2011 | 02:21 AM
  #33
1SlowHoe's Avatar
Destroyer of Transmissions
Yes, if you are tuned for meth, and your pump fails at wide open throttle, you will probably here the detonation in the engine 1/100th of a second before the engine pops.
Old Oct 12, 2011 | 03:58 AM
  #34
slowec's Avatar
So , is everybody mixing there own or buying some premix stuff. pssst, who is your supplier for your meth habbit?
Old Oct 12, 2011 | 08:46 AM
  #35
nonnieselman's Avatar
I ran a devils own and didnt have any problems for a couple years. Used -30* WWF for awhile. Then switched over to VP1 straight methanol. Towing it helps a good bit, IATs never went over 100*
Old Oct 12, 2011 | 09:28 AM
  #36
slowec's Avatar
So you put the iat close to the thottle body and put the meth nozzle back where it sprays before the iat sensor??
I think I am about to oder a devils own kit :-)
tim wellington
Jul 31, 2015 03:28 PM
Onetogofast
Jul 27, 2015 08:33 AM
fcompean
Jul 15, 2015 09:55 PM
