Ported heads worth it with a magnacharger?
Old Oct 13, 2013 | 09:57 AM
Yukon04's Avatar
Default Ported heads worth it with a magnacharger?
I have some Cnc 317 heads, stock valves that I'm either gonna use or sell just wondering how much gain would be had installing them with my magnacharger. I feel it will be minor being the air is forced jn the cylinders anyways.
Old Oct 13, 2013 | 11:14 AM
1FastBrick's Avatar
Custm2500's Rude Friend
What are you trying to put them on?
Old Oct 13, 2013 | 11:22 AM
Yukon04's Avatar
6.0 Yukon Denali with a magnacharger
Old Oct 13, 2013 | 01:03 PM
gamble686's Avatar
Keep in mind that boost is a multiplier of power. If you make more power NA you will make more power in the boost. The extra flow from the heads may reduce resistance and you will make more power with less boost. Heads can lower your boost and allow you to pulley down more safely.
Old Oct 13, 2013 | 01:21 PM
Yukon04's Avatar
Interesting...thank you
Old Oct 13, 2013 | 01:50 PM
ZO6Ted's Avatar
If they are cnc ported I would def use them even with stock valves and do studs and LS9 gaskets while you're at it! You'll be glad you did.
Old Oct 13, 2013 | 02:14 PM
Yukon04's Avatar
I have both of those ready to bolt in with a gt7 cam
Bluecollar Hotrods
Jun 11, 2024 11:37 PM
Silveradorst07
Dec 31, 2015 12:04 AM
sauldgold
Jul 23, 2015 02:15 PM
jmarkway
Jul 18, 2015 09:23 PM
4B11T
Jul 13, 2015 03:48 PM
