Picked The Truck up From Trick Performance!!!!
Old 03-07-2012, 07:20 PM
  #31
Dusty, that setup is badass! Cant wait to ride in this thing!! Call me or pm me details of your 370" build...
Old 03-12-2012, 12:34 AM
  #32
ONEBAD07's Avatar
Mines next will be dropping it off this comin weekend with rick
Old 03-12-2012, 06:36 AM
  #33
Three6GMC's Avatar
Looks really nice and clean. How did you go about he pcv system? Hey Rick still have those oil feed blocks available? If so just pm me your PayPal and I'll send you the money for one.
Old 03-12-2012, 09:49 AM
  #34
Dusty05's Avatar
The passenger side is vented to fresh air and the driver side go's from the intake, check valve, catch can, back valve cover.
Old 03-12-2012, 01:31 PM
  #35
Boostedon35s's Avatar
Originally Posted by Dusty05
Truck has the 6l80e and 308 gears....I've just got the 76mm turbo at 8psi, HP Tuner's (Sending Logs to Nelson Performance), and 60lb EV14 Injectors.
The intercooler temps at WOT can be up to 45-50 degrees cooler than the procharger 2 core. (The way the GMC air dam's are I don't think my 2 core under the truck was catching much air.)
Truck run's stout and future plans include 2800 Circle D stall and a Forged 370 which is in the works!!!!
Was planning on doing the DOD delete but started the knew engine build!!!
Hopefully someone will chime in on the 6l80e...seem's to be a strong but knew transmission....Allen has it shifting really nice...I think I remember someone taking theres to a place in Houston? Maybe Circle D??????
Thanks for all the replies!!!!!
The 6L80E is a stout transmission but drives like *** if its not tunned correctly. Once tuned so that all the crap is out of it you'll see what I mean. In my Camaro with the 6L80E it would handle a boosted launch at the strip and never even gunt. If however you really want it to hold big power I recomend a RPM transmission kit and converter. Ive seen them hold up to 850+rwhp at the track time and time again. Hope this helps.
Old 03-12-2012, 01:37 PM
  #36
Dusty05's Avatar
Thanks for the advice....I'll look into the RPM transmission kit for sure and I'll be calling Circle D.....
Old 03-12-2012, 01:50 PM
  #37
I have a gauge for that
Atomic's Avatar
The circle D trans shop, sister shop to the torque converter guys, do good work on the 6l80e as well.
Old 03-12-2012, 02:30 PM
  #38
ak2007r6's Avatar
Nice truck. I to need to give Chris a call at circle D about building up my 6l80e
Old 03-12-2012, 03:19 PM
  #39
Ive never had any experience with circle D transmissions but I will give them an A++ on their converters..... Def one of the top brands on them.
Old 03-13-2012, 03:46 PM
  #40
Truck Sponsor
TrickTurbo's Avatar
Looking forward to it. Are we doing the powder coating as well.?
Quick Reply: Picked The Truck up From Trick Performance!!!!
