PCV Issue
Old Feb 7, 2011 | 12:12 PM
Stangbanger's Avatar
Originally Posted by 04SilverCrew
I have the check valve on drivers side from intake to drivers vc. Pass side used to go to inlet side of supercharger but I plugged the procharger intake... just ran pass side vc to a breathered puke can. Hope this helps.
Did you go from the breathered puke can to the TB or just capoff the TB port?
Old Feb 7, 2011 | 12:19 PM
black04's Avatar
Just block off the tb. You can vent the passenger side or run it to the vac port on your blower.
Old Feb 7, 2011 | 12:39 PM
04SilverCrew's Avatar
Cap off tb. Puke can to pass valve cover... and you will be just fine.
Old Apr 4, 2011 | 08:48 PM
HeadGames Dave's Avatar
so..can I get a picture of this?
My truck smokes like a old freight train..
Old Apr 4, 2011 | 10:42 PM
Picture of what? The can? The checkvalve?
Old Apr 4, 2011 | 11:28 PM
The catch can..and how the pcv is ran. My pcv is in the inlet side of the blower
Old Apr 5, 2011 | 12:32 PM
02'Z71ONDUBZ''s Avatar
I would just vent both valve covers, and block off the throttle body and intake ports. I had planned on running a catch can with a ford check valve in line, but after I saw what the inside of my intake looked like with the pcv routed to it, I vowed to never connect the hose again. I just put a little breather on each side of my firewall to vent each vc.
Old Apr 5, 2011 | 09:03 PM
I ran the passenger side to the puke can.Took the valve and hose out of the inlet side rubber hose of the blower. And kept the passenger hooked to the intake. And the smaller hose went to the vacuum on the blowoff? Am I kinda correct? The truck still smokes
Idryfly5
Sep 2, 2022 08:55 PM
lucas287
31
Jan 12, 2021 06:18 AM
TAPyvehc93
Sep 14, 2015 01:22 PM
dselby25
Sep 11, 2015 05:03 AM
Boyes50
Sep 8, 2015 12:06 PM
