p1 how much psi
Old Oct 18, 2009 | 01:53 PM
phasemaster1's Avatar
After 12psi belt slip with 6-rib what you need to calculate is impeller speed
Old Oct 18, 2009 | 03:40 PM
Mangled03gmc's Avatar
Baltimore Whore
He will not have a problem getting 10 + psi on a 6.0 with the P1.. Is what I am getting at here
Old Oct 18, 2009 | 03:50 PM
Most Hated's Avatar
so then after 10psi ,the belt stats slipping?
Old Oct 18, 2009 | 03:58 PM
sharpshooter's Avatar
not mine
Old Oct 18, 2009 | 07:19 PM
Sharpshooter, what psi are you seeing with 4.25 and D1
Old Oct 18, 2009 | 07:21 PM
@ 6000 rpm's it makes 11#'s
Old Oct 18, 2009 | 07:35 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Marco will probably see less than that with his huge cam. But I'm just guessing.
Old Oct 18, 2009 | 07:44 PM
Maybe Im wrong but John is making that with the P1 and 3.6" pulley you have a D1 and a 4.25"
Old Oct 18, 2009 | 08:04 PM
I'm not understanding?
If you are referring to my post "not mine",it is directed to the post just above it about belt slip past 10#'s.
and the difference between John's set-up and mine that you stated makes sense to me
Old Oct 18, 2009 | 08:27 PM
What Im trying to say is that after 12# belt slip will be encountered on a P1 running that small of a pulley. You havent because you run a D1 and your already at 11# and have a 4.25". Much more belt wrap.
