P0068 after TVS install
Old Mar 7, 2010 | 08:07 AM
duckhunter1999's Avatar
Registered User
Did you use the factory map sensor that was on it before. Did it fit the same as the one Roush recommends? If so, then do we really need to change this out?
Old Mar 7, 2010 | 10:04 AM
smokeshow's Avatar
Mod with training wheels
I did end up using the factory MAP sensor because my ECM was tuned for it. I will eventually have it tuned for the 2bar map sensor that Roush recommended, but not until Justin has a free EFI live cable to send me.
Originally Posted by bud8fan
nice...that 60e isnt going to like you very much...
I rebuilt the tranny with pretty much everything possible, so it should take the beating. The G80 back there also seems to work smoothly. The trutrac will take its place eventually though.
Old Mar 7, 2010 | 10:07 AM
Registered User
Did the factory map sensor fit the same?
Old Mar 7, 2010 | 10:17 AM
smokeshow's Avatar
Good question lol, no it did not. The new map sensor is a bolt on kind with a bigger insert. So my old one was just the clip on style with an insert too narrow for the bore in the intake manifold. Fortunately, the bolt for the new map sensor still holds the old one in place. And I just put some additional o rings on the old sensor to make it fit the size of the bore. Got about 50 miles on it now with that setup and no codes.
Old Mar 7, 2010 | 10:23 AM
Registered User
Here's a question for you, could you use the new map sensor and connector that is recommended and not hook up the 4th wire that is cut and spliced into?
Old Mar 7, 2010 | 10:27 AM
smokeshow's Avatar
Since that wire is needed for the new sensor, probably not. You can either use the old one with 3 and an ECM tuned for that sensor, or vice versa.
Old Mar 7, 2010 | 10:30 AM
Registered User
Well I'll probably do what you did since I already have my tuned ECM from Justin, and then wait for an EFI cable.
Old Mar 7, 2010 | 10:32 AM
smokeshow's Avatar
That's exactly what I'm doing. For the o-rings, they have them at checker...you just need to increase the diameter of the insert by a hair so it snugs up in the bore nicely. And the bolt will overhang the old sensor's clips to hold it in place.
Good for a temporary fix until Justin has some spare cables.
Old Mar 7, 2010 | 11:29 AM
Registered User
So I'm guessing the kit fit without a different hood? Roush told me you needed a different hood, I guess there wrong.
Old Mar 7, 2010 | 12:15 PM
smokeshow's Avatar
Nope, stock hood. There's quite a bit of clearance actually, I'd say 2 or 3 inches.
