Overdrive crank pulley?
Old Dec 31, 2015 | 02:57 PM
  #21
03sierraslt's Avatar
Originally Posted by Dans 05
How much did it bump up your psi over the stock pully
If I recall it was like 2-2.5psi
Old Jan 8, 2016 | 12:05 PM
  #22
embs2001's Avatar
Is there any calculation I can use to figure out how much it will increase my boost?
Old Jan 8, 2016 | 12:30 PM
  #23
Vortec350ss's Avatar
Not exactly... but you can figure out what the equivalent upper pulley would be with the stock balancer if that helps you at all.
just divide the upper pulley by 1.1.
Example if you're using a 3.0 pulley now it will be like a 2.725" after the OD crank. The rule of thumb is approx 1# per .1" pulley drop with a maggie.
3.0/1.1 = 2.727
Old Jan 8, 2016 | 01:02 PM
  #24
embs2001's Avatar
3.0/1.1 = 2.727
Makes sense.
Im at 8.5-9 lbs with 2.95 upper and 7.72 crank. So 2.95/1.1 = 2.68.
So a increase of about 3 lbs
Thanks!
Old Jan 8, 2016 | 02:03 PM
  #25
Dans 05's Avatar
I've had the power pond for a couple years, no issues.
When you did the overdrive pully did you switch every thing to 8 groove or did you run the 6 groove
Old Jan 8, 2016 | 03:58 PM
  #26
I ran 6 rib for a little while, 5-6m then switched it to 8 rib.
Old Jan 8, 2016 | 04:29 PM
  #27
Dans 05's Avatar
When you switched did you returned the truck or will the computer compensate for the change
Old Jan 8, 2016 | 05:04 PM
  #28
From 6-8rib? Or to the overdrive crank pulley?
Old Jan 8, 2016 | 05:05 PM
  #29
Dans 05's Avatar
To the overdrive
Old Jan 8, 2016 | 05:37 PM
  #30
Yes you have to retune, if you add boost you have to retune period.
