oil temp for turbo guys
Old Dec 1, 2011 | 01:05 AM
  #21
Atomic's Avatar
I have a gauge for that
I should have my fittings tomorrow to make everything work. My trans is out getting fixed though, so itll be a few weeks before I drive it again...
Old Dec 1, 2011 | 06:12 PM
  #22
ayousef's Avatar
its about time someone thought of checking his oil temp, did you try to verify your oil temps using the sensor, with the readings you get from HPTuners? Im asking because HPTuners gives an oil temp reading.
I ordered a big a** radiator with built in engine oil cooler and a transmission cooler from Ron Davis, its 3 times thicker than the stock unit, and also has a shroud with dual high speed fans.
Reason im doing this is because I have a feeling my oil temps are skyrocketing with this much power and the usual very hot weather here, "estimated" temps also read high on HPTuners, assuming they really are estimated.
Old Dec 1, 2011 | 06:46 PM
  #23
Atomic's Avatar
I dont think HPT has that feature for my year....even if it did, I dont think its useful since there isnt an actual sensor to measure it.
Old Dec 3, 2011 | 10:18 AM
  #24
Atomic's Avatar
Gonna give this a try soon
Old Dec 3, 2011 | 10:27 AM
  #25
kbracing96's Avatar
So you gonna get the turbo oil and temp before it goes though the cooler???
Old Dec 3, 2011 | 12:31 PM
  #26
Atomic's Avatar
Yea, I wasn't sure how much pressure drop I would have after the cooler so I wanted to make sure the turbo always had pressure. And that top fitting is metric so I would have to order an adapter thing.
Old Feb 25, 2012 | 05:24 PM
  #27
Atomic's Avatar
So as an update, the cooler works great. Oil temps hover around 210 with easy driving.
TAPyvehc93
Jul 23, 2017 10:54 PM
Go5.3tt06
Sep 12, 2015 09:29 AM
fillpot
Jul 26, 2015 07:21 PM
lxcoupe
Jul 21, 2015 02:12 AM
GM-only
Jul 19, 2015 10:48 PM
