Oil return
Old Feb 15, 2015 | 04:14 PM
Moneypitt's Avatar
Default Oil return
I am trying to figure out where to drill and tap the oil pan for the oil return on a turbo, I am building a motor/trans combo but don't have a truck yet to put it in. I am planning on buying a 2000-2004 2500HD to put it in, I just want to make sure I don't run into clearance issues.
Old Feb 15, 2015 | 04:43 PM
walledition's Avatar
Originally Posted by Moneypitt
I am trying to figure out where to drill and tap the oil pan on a 4l80e for the oil return on a turbo, I am building a motor/trans combo but don't have a truck yet to put it in. I am planning on buying a 2000-2004 2500HD to put it in, I just want to make sure I don't run into clearance issues.
you have to drill the motor pan not the trans pan for the turbo oil return and this is where i did it, right above the oil sensor
Old Feb 15, 2015 | 04:48 PM
George C....'s Avatar
Formerly ScreamingL
you want the oil drain to be above the oil level in the Motor's pan not the trans pan
Old Feb 15, 2015 | 06:55 PM
Moneypitt's Avatar
Ok thanks, brain fart.
Old Feb 16, 2015 | 01:12 PM
GRRR65GTO's Avatar
I did mine right in the front of the pan next to/under the crank pulley
Old Feb 20, 2015 | 12:24 PM
Ferocity02's Avatar
Mine is right above the oil level sensor too, but about 3/4" higher than shown in the pic above. Works fine with a -10 return line.
Old Feb 20, 2015 | 04:32 PM
zachm89's Avatar
Mine is right on the front of the pan to the drivers side of the crank pulley.
lukn4trbl355
Oct 21, 2015 11:19 PM
blackedoutchevy22
Oct 1, 2015 08:07 PM
sTNT971
Sep 26, 2015 04:22 PM
lxcoupe
Sep 25, 2015 12:36 PM
97_ek
Sep 23, 2015 09:16 PM
