OIL coming out of exhaust!!!
Yes , I did a search . Found some things and checked some stuff. The pump is running, I jumped the pressure swicth to run it on high. No oil is coming out of the cap . I can blow thu the return line "not clogged"The buzzer is on. This is a used kit, so endless things could be wrong. I don't even have the wastegate on as I have to drive to my tuner. Needless to say , any help is needed and I thank all of you
Is it possible someone sold you their problem?
Could the main seals on the turbo unit be bad?
Have you looked into your intake manifold through the throttle blade with a flashlight? See if there is a lot of oil build up back in the intake manifold.
It's a long shot, I doubt the combustion chamber would allow oil to pass anyways.
Hope you find a solution.
Jim
Jim
Originally Posted by slowec
Pump runs bass ackwards. Reverse polarity and we're off to the races to get tuned. I 'am boosted biatches!!!!
Glad you caught it soon!
Jim
