Normal amount of coolant use?
Old Oct 1, 2013 | 11:26 AM
Ferocity02's Avatar
Default Normal amount of coolant use?
I installed my turbo kit back in April/May and this morning the low coolant light came on. The coolant was at the correct level at the time of the install and I never added coolant since. I have LS9 gaskets and ARP studs, pushing around 9-11psi and 16 deg of timing. I hit that boost 1-2 times a day and only for a few seconds each. There's no visible external leaks, it feels great, no odd smells or white smoke out the exhaust. Oil looks good also.
Is there a "normal" amount of acceptable coolant use on a turbo vehicle? I feel like it shouldn't use any at all.
I'm going to top off the coolant today and we'll see how long it takes to drop again.
Old Oct 1, 2013 | 02:13 PM
foose04's Avatar
I would check under neath the truck, where the heads meet the block. When I started to push 18+psi on stock bolts, mine had a very small leak there towards the firewall side of the engine, but never mixed with oil or smoked.
Outside of that, I don't use any coolant. You have a 25-50% coolant mix/water? Or straight dex?
Old Oct 1, 2013 | 02:23 PM
SLCviaAK's Avatar
It could have burped an air pocket out of the system after a while of being put back together from the head gasket install. Just a thought.
Old Oct 1, 2013 | 02:27 PM
Ferocity02's Avatar
It's around a 50/50 mix.
I looked all over and didn't see any leaks, I'll check again today.
bearden86
26
Nov 15, 2015 03:58 PM
lukn4trbl355
Oct 21, 2015 11:19 PM
nabozny21
Oct 17, 2015 07:47 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
sTNT971
Sep 26, 2015 04:22 PM
