Nnbs turbo problem
Yea I had to replace the drive shaft and one injector the previous "tuner" installed was leaking bad but my new tuner fixed that and tuned the truck. It's running good now just on very low boost at 5#. Since it's on 3 kit gotta change the wastegate, move the bov, and put a camaro maf. New tuner needs me to cam it to raise the boost, just not sure if it's worth putting a cam into a 4.8 or just going big for a 6.0🤔🤔
If the MAF sensor is already a card style MAF, there is no reason to upgrade it. Going to a camaro MAF isn't going to change anything as they would both still be card style MAF's. You should still have plenty of room on the table in a 3in pipe to keep going up in boost. If you get close to the limit just install the MAF in a larger 3.5in intake pipe.
As for the boost, you can slam the 4.8 with 10-15lbs on the stock cam and make good power. Needing a cam to raise the boost is a dumb comment on his end.
This x2
