Nissan Frontier Turbo Project
What you need is an FMU like what procharger uses in there base SC kits. Its a rising rate fuel pressure reg that will increase fuel pressure as boost increases so the injectors will squirt more fuel with the same amount of open time. Some people say its a band-ade kinda fix, but I used one on the 2.8 S-10 I turboed and it worked great!
Yeah I will try it how it is then maybe add the FMU. I think it will probably work fine without. Im only going 5psi max. Don't think there will be any need for tuning. My truck ran just fine with the procharger and stock tune. that was @ 10 psi. I really didn't notice crap with a tune and the procharger.
Does it have a MAF? If so, it will probably work fine with low boost. I forgot my S-10 was a factory SD tune, TBI motor.
Yeah procharger had a fmu, i meant i didn't notice anything switching to larger injectors and a tune. I was running 10 psi with a stock tune and fmu. The Nissan does have a MAF built into the TB. I think it should run fine.
