NGK tr6 spark plugs?
Old Oct 23, 2013 | 04:42 PM
smokeshow's Avatar
Mod with training wheels
In that case I might gap them tighter. Spark has a higher tendency to blow out in a higher pressure and temperature environment.
Old Oct 23, 2013 | 05:02 PM
GMCtrk's Avatar
I'd gap them tight. Also, I've never noticed any difference between TR55s to the BR7EFs in how the engine ran.
I ran BR7EF at .032" and was having blow out issues when I tried to go above 12 psi. But, when I pulled the plugs I did find #8 @ .035". Got a new set and am going to run them out of the box (.022-.024")
Old Oct 26, 2013 | 08:47 PM
trxmxzx's Avatar
13 Second Truck Club
i dont mean to highjack but i wonder if this is my issue, running .038" gap, rough as hell idle, in boost it breaks up
time to play with it tomorrow
Old Oct 26, 2013 | 08:55 PM
Chevy_King1500's Avatar
I run tr6s in mine, opened the box and put them in.
Old Oct 27, 2013 | 03:27 PM
muncie21's Avatar
TR6's are all that I run in my SC'd vette. No problem in over 5 years. Now I've changed them a time or two, mostly because I'm OCD, not because I needed to.
Old Oct 27, 2013 | 06:59 PM
timmay208's Avatar
sounds like that may be your issue, that gap is a bit high
Old Oct 28, 2013 | 05:38 AM
Jontall's Avatar
I've had great luck with C6 Corvette LS7 ACDELCO Part # 41104 iridium spark plugs. GM also uses them on all their supercharged engines and there is a rebate available right now. They are the same heat range as NGK TR6.
http://www.acdelco.com/pdf/Spark%20P...ate%20form.pdf
twake_410
Apr 14, 2016 09:58 PM
00loudchevy
Dec 3, 2015 05:54 PM
bearden86
26
Nov 15, 2015 03:58 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
KleanKustoms
Sep 30, 2015 05:07 PM
