Next step For Injectors?
11 sec. Truck Mod
Originally Posted by dewmanshu
What makes you think you need injectors anyway?
Originally Posted by TIM Z
tommorrow my son , tommorrow!
!I want to hear about you pipe wrapping too. I got the stuff, but waiting for my new scan gauge to get here, so I can compare 0-60mph with the T-70 and the T-60, both being wrapped
11 sec. Truck Mod
Originally Posted by kbracing96
Get on it
I have the 60s and they have been great. No idle problems or anything else.
I bought new connectors from summit for $12 and spaced up the rails. It was pretty easy, but it does make you a little nervous hacking into your wiring.
I probably would have went with 44lbers, but my injectors came with my turbo. I am glad to have them though, this way I don't have to worry about ever needing to buy bigger ones.
Just get Allens kit that comes with the spacers and pigtails, cant beat the price either. Like I told you earlier tim I would do the 60's
Guys, 44# injectors will cover you up to 500 crank hp (so ~400-425 rwhp) for a turbo (BSFC of 0.65, 58psi fuel pressure, and an IDC of 80%). Unless you are past that or planning to go past it, 60lbers are over kill.
Wilde is running ~11psi there at 90% IDC in Nevada heat.
*****yep he does, so that helps somewhat bring done those duty cycles and combat some desert heat. I know not all, but a big help though.
Originally Posted by Lord Aries
Allens kit? Do you have a link? Thanks
http://www.nelsonperformance.com/products.htm#fuel
This is off of allens site Nelsonperformance.com
