NEW PRODUCTS, Black Series Display Controllers.
https://www.performancetrucks.net/fo...d.php?t=395474
The V gauge would be the one to use if you wanted to know how much water meth you have left in a tank, and use the air fuel safety cut if using an electronic boost controller. Get 2 boosting and go lean the output controll would trip a relay dropping you back down to the springs set point. We are working on more unit but these got finished first.:) Thought I would share what we have been up to lately. Now back on the Avalanche kit. Rick |
Man, those things look nice.
Could a boost controller be integrated into one of those things. :D |
It already is. ;)
Ricky |
damn...how much are those things? (I like the 19) if it has to stay off the boards, please pm me.
Thanks! |
Thanks! The V TPP-00029 gauge is 375.00 And the P TPP-00019 is 399.00. Let me know if I can help you with anything. Rick |
do you have a link to the install instructions for the 19...I want to check out how it would connect to my wideband (LC-1).
now I have to get the squeeze...great!!! Goodbye tranny, rear, hello loan officer :drool:
Rick |
10 afr = 0.5 volts 12 afr = 4.5 volts the green wire will connect to that output. Hope this helps. Ricky |
Could i get some more details about the built in boost controler? As in is everything included, electric and general info on accuracy. Thanx
