New meth tank pics!!!
Thanks guys! piece of cake to install. Yes I did a 2 min polish job on the top of the tank alittle bit just to add alittle bit of BLING!!, sides you don't see as much of. It took more time to mount the meth pump than it did the tank. The fill cap has a vent built in, I was wondering the same thing when the tank came in but looked at the cap and saw the vent built into the cap. Very happy with the tank, very tight fit but, It goes in just like it should.
I think it will hold between 1-1/2 and 2 gallons
man that looks nice!!!!
What about vaccum that is created when the level starts dropping????
I wish i had a Tig Welder...
We can also build these with 2 compartments. If someone wanted water meth and IC water tank etc.
A few questions...
-Can I get the actual external dimensions?
-Are the Al and SS tanks the same price? ($225 quoted above)
-What bungs (size and thread) are installed?
-How do we order? I didnt see it on the trick site.
-Any option for black powercoat?
I think this would be a great replacement/upgrade to the small cheapo plastic unit that came with my KB kit.
A few questions...
Aluminum or Stainless will cost the same. Aluminum is thicker then the stainless thats all.
Bungs, can be your choice. Male AN, Female pipe. We work with your needs and, everyones needs are all a little different. Working on one right now with a level sensor in it.
Drop me a PM.
Stainless steel can be powdercoated,
Aluminum can be powdercoated, anodized, or even polished.
We can get the tank LASER marked to if you need to promote logos, companies, etc.
We will do everything we can to make this tank YOUR tank not just an off the shelf part.
Stainless steel is a must if running water/meth, and can be used with water cooling as well.
Aluminum is for water cooling, or standalone fuel systems.
Thanks for the kind words guys. I know I need to work on the website, but we have been overly busy with turbokits, and electronics.
V gauge won BEST NEW PRODUCT at the SEMA show.
Rick
