new to fi!
Old Feb 15, 2013 | 12:56 AM
asap216's Avatar
Default new to fi!
well guys im buying a used procharger setup from a member on here hopefully before the end of this month. its comes with everything except the belt and injectors. I have a set of fast 65 lb injectors so that wont be an issue except for the harness adapters i need to get. my questions are after i do the install is their anyway how i can run it enough to get it to a local tuner without destroying my engine? Do i have to upgrade my fuel pump.. i plan on running a mild tune so i think i could get away with the stocker but not sure. And anyone know what size of belt i would need.. the only thing ive done to the drive belt system is a bigger 145 amp alternator compared to my old 105.
I know a lot of questions but i just want to sum it all up that way i know if i need to tow my truck and how much additional money i will have to lay down!
thanks in advance!
Old Feb 15, 2013 | 01:10 AM
Atomic's Avatar
I have a gauge for that
You will need to upgrade the fuel pump. Make sure your tuner has data for those injectors. You can always keep the stockers in, drive to the tuner, and swap in the new ones in the parking lot. Just BABY it on the way over and it will be fine. That means no boost!
Old Feb 15, 2013 | 01:20 AM
asap216's Avatar
Texas Speed and Performance - Racetronix In-Tank Fuel Pump Upgrade Kit
would that suffice?
Old Feb 15, 2013 | 09:53 AM
Atomic's Avatar
Depends on how much power you want...that pump would support around 500hp.
