need help / advice lq4 +boost
That is a great cam for a NA engine, but why not put a 'boost cam' in it if you're going through all of the trouble of swapping cams? You don't need a huge cam to make good power on a turbo charged application. A smaller cam will also allow you to run a tighter converter which will increase the drivability of your daily driver. When I went FI, my Texas Speed 220 cam came out in favor of the Isky triple 12. I'm pretty sure stock48 made it into the low 10's with that cam in a 6.0l and a lot of boost
Boost is all new to me, I asked about that cam since a local is selling it pretty cheap with springs.......i really dont know what should be used as for a cam so any advice is welcomed
Well the timing chain is no big deal, they arent that much. I did cam, chain, pushrods, springs and had the heads redone but no port/polish in my trucks 6.0 that has been bone stock for 115k and im hopin for 500 rwhp
I've herd of some braking the 10 second club but was on 18+ psi not something I want to do.........
That is a 6.0. Not a 5.3 that has lower then stock compression. Like i said it isn't completely impossible but with out a slip and better yet a video, it didn't happen.
