need advice
well guys the walbro took a dump on me i was looking at the denso 300lpr fuel pump are there any guys out there running this pump and if i install this pump will i have to retune for this fuel pump
Atomic is doing a dual intank project with the Denso's.
https://www.performancetrucks.net/fo...d.php?t=471680
You might want to look into adding a hot-wire kit with whatever pump you go with. The #1 reason for pump failure is insufficiant amperage/voltage form using the factory wiring.
As long as you keep the same FPR, you won't need to retune.
Rick
Rick
lycominghunter
26
Sep 25, 2015 07:50 AM
Cha_Feel_
Sep 23, 2015 09:06 PM
