is my cam too much for a turbo?
Old Jul 16, 2008 | 07:51 PM
mikeith's Avatar
Default is my cam too much for a turbo?
i have a stock 5.3 w/ 243 heads(ls6), headers and the cam is a
its a 222/226 .581/.588 112lsa 0 overlap
i would like to do a turbo this fall but im affraid that i may have too much cam for a turbo... i only want to run 5-6 lbs of boost. when i talked to the rep @ sts his main concern was that the cam had 0 overlap which it does but he didnt know how it would act w/ a turbo
will it work ok and what things might i need to be worried about?
Old Jul 16, 2008 | 08:09 PM
Stoichiometric's Avatar
More overlap will allow more reversion when you are in boost. You also don't need a cam that large to flow the air you are after once you have a turbo. Try it, if it doesn't work out there are better cams out there for your application.
Old Jul 16, 2008 | 08:41 PM
charcold-bowtie's Avatar
Try it. Get a front mount tho. Im moving to Lbk in about a month i think
Old Jul 16, 2008 | 09:21 PM
mikeith's Avatar
ehhh i already have pacesetter's and besides the sts is WAY more cost effective if you do a universal kit
Old Jul 17, 2008 | 11:17 PM
BigTex's Avatar
That cam is a bit large and not an ideal profile for a turbo, but its gonna run fine at 5-6psi. If you change it, you'll move the powerband around some and probably gain a few hp. At that low boost level, it would be minimal difference.
elpyro89
Jul 28, 2015 05:51 PM
lxcoupe
Jul 27, 2015 08:19 PM
WICK3DxGATA
Jul 21, 2015 06:59 PM
black6spdz
Jul 16, 2015 01:32 AM
Atomic
Jul 11, 2015 03:51 PM
