MP112/15lbs of boost on 402CID 600/700 to the wheels......video link
Old Sep 20, 2007 | 10:20 AM
  #21
BlownChevy's Avatar
blownerator
25 Year Member
That guys is an ***.....even my Magna Charger cheer leading *** does not believe it.
Old Sep 20, 2007 | 10:56 AM
  #22
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
LMAO thats sig material right there.
Old Sep 20, 2007 | 04:23 PM
  #23
moregrip's Avatar
what a rush!
like I said, he's been pretty legit about his setup so far, I'm interested to see where it ends up
Old Sep 22, 2007 | 12:15 PM
  #24
Blown2300's Avatar
nope.. something is wrong with that setup..
unless he installed the "tornado" in each runner..
Definate BS!!!
Old Sep 22, 2007 | 10:48 PM
  #25
desTRUCKtive's Avatar
Originally Posted by thunder550
Doesn't condensation form on the WARM side of the surface? I'm definitely calling BS on this one.......
So let's think about this for a minute. If a 3.0" pulley makes about 9-10 psi on a small overlap cam in a 5.3, and a 2.8" pulley makes about 9-10 psi on a small overlap cam in a 6.0, we can extrapolate this into the theory that a 2.6" pulley (if it were even available) would make 9-10 psi on a small overlap cam in a 6.7 (402/408). (I'm assuming a front drive Radix here, for simplicity)
Let's go back to the 5.3 and 6.0 for a minute. Every drop of .2" in the pulley yields roughly a 2 psi increase. Let's ignore belt slip for a minute, and assume that this means that every .1" drop in pulley diameter yields a 1 psi increase in boost pressure. To get from 10 psi to 15 psi on the 402, we would have to drop from a 2.6" pulley to a 2.1" pulley. Again, this doesn't even account for belt slip, which would be enormous at that level (which is irrelevant anyway since you can't fit anything smaller than a 2.75" pulley, but I digress......)
So here we are, with a 2.1" pulley on our front drive/single pulley Radix on our 402 with no belt slip occurring. Completely impossible situation, but what the hell. Let's figure out how fast the blower is spinning anyway.
The stock crank pulley is roughly 7.5" diameter. 7.5/2.1 = 3.571. The supercharger is spinning 3.571 times faster than the engine. Since he doesn't say how fast he spins the engine, I'm going to assume a nice even number like 6000 RPM. At 6000 RPM, this means that our supercharger is spinning at roughly 21,426 RPM.
I'm not 100% positive on this, but I think I remember reading somewhere that the max allowable RPM's on the Radix-style blowers was about 18,000. Any faster than that and they ran the risk of damage from the rotors contacting each other. It's pretty safe to say that 21,500-ish isn't possible, which is why I call total on this guy's results.
What are you some kind of Engineer?? j/k bro
Old Sep 30, 2007 | 02:25 PM
  #27
moregrip's Avatar
what a rush!
haven't read anything new.......hopefully there's more info to follow
Old Oct 13, 2007 | 09:18 PM
  #28
moregrip's Avatar
what a rush!
I'll be tuned in to see how it turns out:
http://forums.corvetteforum.com/show....php?t=1837369
Old Oct 13, 2007 | 10:30 PM
  #29
2004SSS's Avatar
says he has a 2.65 pulley.
but he shoul dbe faster than 10.9 imo its a light *** vette with a stroke dblown motor. with that combo 10s shoul dbe a breeze.
Old Oct 13, 2007 | 11:38 PM
  #30
James B.'s Avatar
...I'm going to assume a nice even number like 6000 RPM. At 6000 RPM, this means that our supercharger is spinning at roughly 21,426 RPM....I'm not 100% positive on this, but I think I remember reading somewhere that the max allowable RPM's on the Radix-style blowers was about 18,000. Any faster than that and they ran the risk of damage from the rotors contacting each other....
EXACTLY. I'm always amazed by how some people so willingly disregard such relevant limitations. I see it a lot in the F-150 Lightning crowd with Eaton blowers. It's so cheap and easy to just swap some pullies and belt than it is to upgrade to a proper displacement supercharger for the job! Personally, I am less willing to pick little chunks of rotor out of my intercooler core, cylinder heads, and pistons.
On my setup, Whipple's redline for the 2.3L is 16k, for example. I run a 7.5" crank pulley, 2.625" compressor pulley, and shift at 5600RPM. Mathematically, it doesn't get any better than that. Roots (Eaton) can spin faster because the second rotor isn't overdriven like it is in screws, but even still, 21k+ is WAY past safe. It's a bomb. Kind of like sending power through a 4L60-E...
