Meth at what PSI.
08 Silverado 4.8 (LY2) daily driven. 4l80 swap, triple disc stall, KB t72 intetcooled. Question is what is the most psi I can run without meth? (Using it for insurance not power) I got arp studs n ls9 gaskets. Lunati dual springs high lift. Looking into alky control kit. But just want to be safe until I buy it. Thanks guys.
Depends on how your IATs act.
its kinda a loaded question, but if your tune is good and you use good gasoline. prolly say around 10-15psi.
how big of injectors do you have?
My tuner says below 11psi meth/water injection isn't really needed. So per his suggestion, my plan is to run a street boost setting of 5-8psi w/o injection, and a spirited setting of 12-15psi w/ injection. But as mentioned, there are many other variables, so I might end up spraying at both settings.
9 Second Club
Mine starts about 5psi and sprays with the number 1 Injector duty cycle. The harder my injectors work the more the pump works. Keeps egt's down while towing and racing. It's a win win.
