meth on two step
Old Dec 3, 2015 | 11:15 AM
Vortec350ss's Avatar
Bend rods by spraying too much fluid into the chamber? Almost like a hydro-lock type situation?
Just thinking out loud, but unless the unburnt meth isnt exiting the cylinder i dont really see how that would be any different than when there is spark. Hmmm... interesting none the less. George can you elaborate at all?
How would you stop the meth from coming on while you hit your target boost or MAF reading?
Old Dec 3, 2015 | 11:23 AM
dsmmace's Avatar
Meth Backfires were nasty. Once you go past the fuel/meth threshold, it wouldn't ignite or cause uneven cylinder distribution.
I used an Alkycontrol.com kit, it was a progressive injection kit with a MAP sensor.
Old Dec 3, 2015 | 11:36 AM
Better to go with a trans brake on that 4L80 and just move the 2 step rpm to where you make the most boost....unless the torque convertor still limits rpm with a trans brake engaged....I am not sure.
Old Dec 3, 2015 | 12:09 PM
George C....'s Avatar
Formerly ScreamingL
also most meth kits arent spraying till 9 psi so you shouldnt be on spraying meth on the 2 step
Old Dec 3, 2015 | 12:14 PM
Formerly ScreamingL
correct and same goes for when you bounce off rev limiter while spraying meth...if you cant ignite that fuel where do you think it goes? Ive bent 4 rods doing this...Mechanical over rev, motor went past the limter but meth stayed spraying
....came back and motor was idling alittle funny...did compression check and was down on 4 cylinders...tore motor down later on and discovered the 4 rods
stock48 spoke of same thing on his nova
also if you talk to Julio about meth setups hell tell ya not to use it on 2 step, it can create some ugly back fires, thats why his had a wire to shut meth off on the transbrake/2 step
vVandals909
13
Apr 12, 2019 10:31 PM
Tuskyz28
Jan 22, 2016 08:16 PM
GMCtrk
Nov 26, 2015 05:06 PM
40series
Nov 19, 2015 07:17 PM
85k10
Nov 5, 2015 06:30 PM
