meth on two step
Old Dec 2, 2015 | 03:14 PM
tim wellington's Avatar
Default meth on two step
any body doing this . pro's and con'. tried last night can make 1 lb more boost any one
Old Dec 2, 2015 | 03:34 PM
George C....'s Avatar
Formerly ScreamingL
Dont use meth on 2 step
Old Dec 2, 2015 | 10:53 PM
Default meth
thanks minster c
Old Dec 3, 2015 | 08:25 AM
TXsilverado's Avatar
For us noobs to meth and boost, why not?
Old Dec 3, 2015 | 09:01 AM
Formerly ScreamingL
Instructions say dont....thats good enough for me
Old Dec 3, 2015 | 09:47 AM
instructions also say that headers, some turbo kits, nitrous kits and some blowers are for off road use only...
Old Dec 3, 2015 | 10:06 AM
Atomic's Avatar
I have a gauge for that
I do it, never had a problem, but I don't hold the 2 step for very long either. I imagine there might be a slight risk of a backfire if the 2 step malfunctions and you are spraying a **** ton of meth.
Old Dec 3, 2015 | 10:34 AM
Formerly ScreamingL
Also can bend some rods
Old Dec 3, 2015 | 10:36 AM
Default meth own 2 step not going to be greedy
now i scared to try again . i was just looking more boost leaving when had converter issue launch at 3 lbs now 6-7 lbs lauch (nite and day differ) .i was trying to get 10 lb launch .think i will try hydo boost brakes .again thank for replys
Old Dec 3, 2015 | 11:13 AM
dsmmace's Avatar
Meth is great in most applications, but you need to be aware of the threshold of meth to gasoline ratios. Otherwise backfires will happen.
Things I've experienced in my DSM days:
Blown intakes manifolds and or gaskets, head gaskets, bent rods and intercooler endtanks splitting.
But then again I also ran 24-26 psi on a smaller turbo on the street daily to 120mph in the 1/4.
I started introducing meth into the system once I passed 15psi, under there was no need. Ignition timing and a two step played a bigger role on spooling the turbo. Otherwise, spray it.
