Meth solenoid location
Old 09-08-2018, 02:04 PM
TXsilverado's Avatar
Default Meth solenoid location
i have several options on where to mount my holley meth solenoid. I originally chose near the throttle so the meth could atomize best, then saw i have options on the back of the blower that seem like more of a direct path to the intercooler. Which would you choose and why? Dont mind the mess. The car has been under the knife for almost 4 years now.
Old 09-09-2018, 09:18 AM
I have a gauge for that
Atomic's Avatar
Is there still a nozzle on the end?
Old 09-09-2018, 06:45 PM
03sierraslt's Avatar
If you do post throttlebody then be sure you have a check valve or the vac will suck the meth in when it’s not spraying. Personally I would want it to be atomized prior to hitting the rotors.
Old 09-10-2018, 07:56 AM
SUTTERERMAN85's Avatar
Wont the solenoid stop that from happening? I would run a nozzle for sure reguardless of where you put it.
Old 09-10-2018, 11:46 AM
the term solenoid confused me as well. The Holley meth solenoid works more as an injector than a nitrous solenoid. It is controlled by one of the injector drivers in my dominator efi ecu. I will be able to flow meth based on percentages of total injector flow (up to 1,000cc/min). If I decide I need more, I can buy up to 3 solenoids to flow up to 3,000cc/min.
since it's tied into dominator efi, I can flow an exact percentage of meth vs. the total percentage of fuel flow present at any RPM and load. I can also use IAT values to determine if meth is necessary or not.
Old 09-10-2018, 11:47 AM
the solenoid should stop it from happening, but I left the check valve in place anyways.
dwood
02-02-2018 09:46 AM
Formulized94
04-05-2011 12:44 PM
NegraRCSB2X4auto
04-09-2008 06:47 PM
scott2004
01-24-2008 10:25 PM
Quick Reply: Meth solenoid location
