Meth Injection
Old Oct 5, 2009 | 04:53 PM
  #31
sureshot's Avatar
Just out of curiousity....if you ran meth on a progressive setup, and assuming you are using the windshield wiper reservoir, on average how long will that last? This is assuming a daily driver situation where you are in and out of boost--not just at the track.
Old Oct 5, 2009 | 05:01 PM
  #32
trever1t's Avatar
2nd fastest 5.3 ECSB
I top off mine every few weeks. ~3 gallons has lasted me over a year.
Old Oct 5, 2009 | 05:13 PM
  #33
sureshot's Avatar
Wow....I didn't think it would last nearly that long!
Old Oct 5, 2009 | 05:39 PM
  #34
TurboBerserker's Avatar
I AM A MOTHERF*CKER
I have one also. Mine is set to '6' and 'come on' ~5psi
This one goes to 11.
Mine comes on at 4psi and is maxed. I also run 3 nozzles.
Old Oct 5, 2009 | 05:44 PM
  #35
BigCountryx's Avatar
Any venders sell Alky Control or is it a direct purchase only co. What about Snow Performance.
Old Oct 5, 2009 | 05:53 PM
  #36
trever1t's Avatar
I have mine set to come on at 5 or 6psi so that moderate driving i don't use any meth at all. Trust me at 6 psi the tires are screaming
Old Oct 5, 2009 | 05:56 PM
  #37
sureshot's Avatar
No doubt about that!
Old Oct 5, 2009 | 06:07 PM
  #38
Mort's Avatar
Give Julio a call at AlkyControl, he is worth talking to. Very personable service and first class parts.
Snow's have lots of kits but look at stage three. I also think you want MAP not MAF control. Are you or will you be running SD then MAP control for sure.
Also a lot of guys like Devil's Own.
Old Oct 5, 2009 | 06:08 PM
  #39
Rick_Vor's Avatar
That was a good call. I set my Snow kit to come on at 2lbs and max at 10lbs. Sucks the 2 quart tank dry on one tank of gas. I should have it come on at 5lbs but then I'd have to have Rick tune it again.
I have a Alky system sitting in the garage waiting for me to install a new shortblock. I'll definetely have that one set at 5lbs intitial boost.
BigCountryx Skip the Snow and go straight to Alky Control. Pretty $$$ but much higher quality of components, fittings, Stainless Steel braided lines, etc. It will come with a washer tank prefitted with the correct fitting for the pump and your low fuild dash light will remind you if it gets low.
Rick
Old Oct 5, 2009 | 07:37 PM
  #40
Sounds like The Alky kit is the ticket. How much should I expect to pay, MSRP?
