MAP Sensor
yes! without one you are boosting the crank case, i have an upgraded one in the stock location from a ford turbo t-bird..
i have the part number posted in my build thread
https://www.performancetrucks.net/fo...thread-504600/
that right there is where you probably have oil coming thru, pull the hose off and check it. then vent the valve cover, cap of the throttle body, and get an upgraded pcv/check valve for the driver side valve cover
Ok so leave the hose off? And by uncapping the TB are you referring to that green cap above it? How exactly do I vent the valve cover? And for that upgraded PCV, can it be found at any auto parts store? Sorry for all these questions lol
Can I just leave my oil cap open an put a small filter on it? Do I also cover the port that connected from the TB to the valve cover?
And from what vehicle did you get your PCV valve from? Looked through your thread an didn't find the part #. So I went ahead and bought a stock one for now
