Magnacharger Vendor/Rep Q's
#31
Joe (760) 522-8669
#34
#35
I apologize if people have asked this before, but I figure go to the source if you have a question. Now granted I do not know the diameter pully you are running, but even with those kinds of numbers and with that much psi introduced into the engine does the MP122HH still "free-wheel" under normal driving conditions, does it stay out of boost? Cause I have read many threads on this site and I've gotten the general impression if you pully down a radix or magnacharger in general it will go into boost quicker and will not "free-wheel" very long which can hurt mpg, etc... Am I correct or am I false? I'm just looking for the right answer.
#36
The rotors are always turning. What you hear about going into boost real fast or too easy is mainly do to intake vacuum. The Bypass Valve is controled by vacuum and stays open so long as you are light on the throttle and have at least a little vacuum. The cam I have keeps about 13-15" of vacuum driving around so no real issue. You will see boost while going up steep grades when you have to hold the throttle blade open more and the bypass valve closes due to little or no vacuum.
silverstreak07
Jun 28, 2016 06:29 PM
scooter k
Sep 16, 2015 10:32 PM
