Magnacharger Intake manifold Gasket
As the title says are there any recommendations for Intake manifold gaskets to use with a magnacharger?
Setup is 6.0l LQ4 with a 112 magnacharger.
I installed it so many years ago I really can't remember what went in and now I have to put in a new Cam position sensor so it needs to be pulled for that sensor change..
Thanks
Thanks
I put an MP122 on mine a few months ago. Stock will work but I had to spend some time at the grinder. You will have to remove the tabs and bumps on the gasket. I also had to clearance mine around some of the ports so it would fit into the grooves on the intake manifold. All in all, no big deal.
Fast86z
Aug 23, 2015 12:35 AM
