MAF location
Old Nov 25, 2012 | 04:07 PM
Atomic's Avatar
I have a gauge for that
Only time the BOV should be open is during high vacuum decel, in which case DFCO is probably active, so fueling should be next to nothing....if thats how he has it set up...
Old Nov 25, 2012 | 04:13 PM
03sierraslt's Avatar
Thats true, I forget about DFCO.
Old Nov 25, 2012 | 04:17 PM
yzriders182's Avatar
I was planing on retaining the MAF.. The more i think of why the only answer i have is because i dont know much about SD tunes.... Time to start learning i guess.
Old Nov 25, 2012 | 04:36 PM
Atomic's Avatar
The engine estimates the amount of air based on the temperature and manifold air pressure instead of measuring airflow with the maf.
Old Nov 25, 2012 | 11:18 PM
jjc839's Avatar
So how do you account for the air lost through the blow off valve? I would bet your transitional fueling is all over the place.
Ya, I thought I might have problems, but on a quick decel the afr would drop from 11.4 to maybe 10.5ish for a moment, didn't make any difference in the driveability. But I'm only running 7psi, so not a huge amount of air being released.
Old Nov 25, 2012 | 11:56 PM
Ferocity02's Avatar
KB puts the MAF right before the TB with a 90 deg elbow right before it. He says there is no issue with this, although I would think a straight pipe would be better.
slimchevy2
Oct 4, 2015 08:02 PM
JordanH
Oct 3, 2015 03:59 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
peebzies
Sep 30, 2015 03:03 PM
94f150
Sep 28, 2015 05:28 PM
