-   FORCED INDUCTION (https://www.performancetrucks.net/forums/forced-induction-159/)
-   -   LY6 boost limit ? (https://www.performancetrucks.net/forums/forced-induction-159/ly6-boost-limit-509140/)
sand man Oct 15, 2012 02:32 PM
LY6 boost limit ?
will I sent Rick @ trick performance the cash to start building a turbo kit for a friend with a 2002 reg cb manual trans 1500 4x4 sierra
the truck has a stock 2008 LY6 with a 228R cam
we got the s480 turbo with a big custom FMIC
what is the LY6 boost limit , the stock CR is 9.7:1
stock piston ring gaps stock pistons stock heads
nonnieselman Oct 15, 2012 02:35 PM
Are you asking about the 2002 engine or the LY6?
You didnt mention which engine is the stock 2002 :D
sand man Oct 15, 2012 03:07 PM
:cheers: typo corrected
i ment a stock 2008 LY6
nonnieselman Oct 15, 2012 03:14 PM
Cool just checking...
with head studs and LS9 head gaskets, 20psi with a good fuel and a spot on tune should be quite fun.
but it all depends on fuel and tune at that point.
sand man Oct 15, 2012 03:18 PM
gas is 91 and if we can push 16psi on the stock rotating we would be happy
aiming for 600whp .. sounds resonable right?
nonnieselman Oct 15, 2012 03:19 PM
very easy.. i pushed mine to 15 psi this weekend and it was awesome.. (LQ4) but lean too by the end of the run :nono:
Atomic Oct 15, 2012 03:20 PM
15-16psi would be as far as I would push it
sand man Oct 15, 2012 03:22 PM
lq4 has 9.4:1 and I suppose you run 93 gas
nonnieselman Oct 15, 2012 03:27 PM
oh just saw 91 octane..
might have to work the tune up slowly.. any plans for Methanol?
nonnieselman Oct 15, 2012 03:28 PM
Yep and Yep..
i just saw you said 91 oct.. might wanna start slowly at 10psi.
