LS9 (ZR1) Cam in a FI GEN III?
Has anyone used this in a FI GEN III 6.0L? I"m looking to upgrade from the LS6 cam to an actual FI cam. I know that on LPE they have discontinued their own cam to use the LS9. I know I'll have to change the front cover, extend the cam sensor harness, and timing chain.
Yes. Just give comp the cam specs on the ls9 cam and they can grind it for you. I know a few people that have done this with having them do a ls6 cam.
Got my ZR1 cam conversion kit ordered from LPE today
After talking to Graham @ LPE, he convinced me it was the right way to go for the 4.8.
I hope to have some dyno results next month, this month I am focused on suspension, wheels and tires.
After talking to Graham @ LPE, he convinced me it was the right way to go for the 4.8.I hope to have some dyno results next month, this month I am focused on suspension, wheels and tires.
I don't think the ZR1 cam would be much of an upgrade over your LS6 cam. Why not get Patrick G. to custom spec you a cam. It will cost you a screamin' $25. The vette in my sig has one of his cams and it's spot on. Excellent manners and 670+ at the wheels on mild boost. There are several outfits that will order you a custom Comp cam, with his specs, for well under $400. Jumping through all of those hoops and spending the same jack to end up with a ZR1 cam is a waste (unless....of course....you have "Blown" in your name and you only have 4.8L to work with......)
