I don't believe stock48 is refering to the C6 Zo6 cam but rather a 02 Z06 cam as being the most optimal stock grind for his setup.
Originally Posted by ayousef
(Post 4872220)
wohohoooow someone's pissed off, ok since I dont know anything and stock48 builds engines for a living I want him to tell me why is a C6 Z06 cam better than a ZR1 cam.
Actually, the LS7 cam would be an upgrade over the LS9 cam. LS7 cam has the same exact lobes, just with a narrower LSA. Narrower = better in this case. The LS7 cam still has a wider LSA than I'd want, but it's 2 degrees better than the LS9 cam. If you want a cam that is smooth and pretty gutless down low, either of these should work fine for you:nod:
Originally Posted by stock48
(Post 4872152)
Because It would have awful low end response, and laggy for my taste. For a larger CI blower application it wouldn't be too bad.
