LS Power!! Twin 76mm Turbo 4.8L 1200HP & still going!!
Old 07-21-2011, 06:23 PM
  #51
schino's Avatar
I guess toss was a bad word to use. I meant in some way hurt a rod other then a rod bolt failure.
Regardless this was an awesome build by hot rod. I'd love to see what it would take to break it and if you had aftermarket pistons and rods in there what the block and crank could take.
Old 07-21-2011, 06:28 PM
  #52
dirty_old_chevy's Avatar
Also, it takes 1260 lb/ft of torque to make 1200hp at 5000rpm. It takes 840 lb/ft to make 1200hp at 7500rpm. Less torque means less cylinder pressure means the rods are less likely to buckle. I 100% agree with LS1FREEK.
Old 07-21-2011, 11:12 PM
  #53
jeffreycastgsx's Avatar
Originally Posted by skolman91
The injectors can be bandaided somewhat with high fuel pressure like mentioned, and the lesser load of a engine dyno might contribute to the smaller injectors being acceptable some.. I see the mentioned bigger fuel rails, any mention of the rest of the fuel setup? Does make it a little hard to swallow seeing just the 75s mentioned.
Now the n/a argument, 450n/a on an engine dyno would probably be around 370ish thru a 60e auto. So that means could a 4.8 with 7/8 headers, fast intake, good heads, and no accessories at all be able to peak @7k rpm with that cam and make 370rwhp. Imo yes it could be done..
I think everybody is overlooking what i would call a pretty impressive top end with that intake and heads. Everything ive seen with a fast and boost has shown really good numbers and performs really well, this is no different..
Do this on a completely stock 4.8 with no upgrades and i think they barely break the 1k mark..?
Originally Posted by Beatdown Z
You don't think a heads, big cam, Fast intake, large primary headers, no accessories, electric water pump, 4.8 can put down 450? Take 20% away for drivetrain losses and you would see ~360 rwhp in a vehicle. Seems legit to me...
As for the injectors, I don't know...
Edit: skolman beat me to it, lol
Maybe i could see that N/A, maybe... Its exagerated. Also remember a engine dyno CAN put LESS and MORE stress on it, and whos to say they beat on it... not me. If they woulda put 100lb injectors and less N/A horsepower then i might believe it.
The numbers ARE inflated N/A and boost, but impressive none the less.
Old 07-22-2011, 12:00 AM
  #54
9 Second Truck Club
stock48's Avatar
Originally Posted by foose04
The fuel injectors come down to fuel pressure. Those 75lb's quickly become 100lb+. I run my 80's at 94 and would go higher if I had a stronger pump setup to support it. I would say they have more then enough pump suppling pressure/volume at the test stand.
As to the power, here's another one, stock crank and rods. It does have pistons though, ended up making 1342HP/928TQ at 7500rpms.
‪1200hp 339 destroked lsx376‬‏ - YouTube
This is a 4.8L rod on the left, 5.3 mid, lq9 on end. Sure hell doesn't look like a 1300HP rod. I would want to be wrapped in armor if I pushed my truck to those levels for a 1/4 pass.
Are the 04 up 4.8L rods thick beefier like the lq9/lq4 floating rods, or did they still the early style light rod?
Old 07-22-2011, 07:30 AM
  #55
1quickRST's Avatar
This article was awesome! Gives me hope for my 4.8...Save the money I was gonna use for a engine swap for a t56.....
Just curious....does anyone know if the reason this test got such interesting results is because they used a turbocharger set up instead of a magnacharger?
Old 07-22-2011, 10:12 AM
  #56
I have a gauge for that
Atomic's Avatar
No....a magnacharger will never keep up with a big turbo in terms of max horsepower, especially twins. This isnt a secret and no one will argue this point. The results are interesting because a STOCK engine took that power and didnt blow up.
Old 07-22-2011, 11:56 AM
  #57
N20GMC's Avatar
Don't get me wrong I think the #'s are alittle inflated but doing some figuring on injector sizing it is possible.
Injectors are rated at 43 psi most of the time. That would mean 75 lbs injectors at the common 58 psi of an LS motor would bring the total flow to 87 lb injectors. Then a 8 cyl engine making 1200 hp at 7500 rpm would have a duty cycle of 74%. Delivering 516 lbs/hr of fuel.
Old 07-22-2011, 01:24 PM
  #58
Laid Back
Beatdown Z's Avatar
I think you may be right about that. Can't believe no one else thought of that...
Old 07-22-2011, 01:58 PM
  #59
Umm, ok good point, i withdrawl my argument then.
Old 07-22-2011, 09:39 PM
  #60
TimDave217's Avatar
so i just took my 5.3 out for a future 6.0L turbo. is this saying i should go to a 4.8L instead and turbo it???? lol or just go back to the 5.3.....
Quick Reply: LS Power!! Twin 76mm Turbo 4.8L 1200HP & still going!!
