LQ4 + boost+ 100 wet shot.
#23
9 Second Truck Club
8~10psi should get you in the 11's easily. The built 4L65 should stand up to that. You might make a 10 sec pass or two on a built 4L65 but it probably wont like it. I have been mid 10's @14~15 psi with a T76 and a 6.0L with good flowing heads. I ran 11.50's @10~11 psi on the breaks at the 1000' mark. Your truck should be 250~300 lbs hevier than mine, but I run at 5000' ~6000' elevation.
#27
single digit dreamer
i had a 6.0 and a 6.7 both with the same cam, both with the t76, both maxed out at 640rwhp but i am sure the 6.7 hit that number at a lower psi. i think the 6.0 was at 14psi and the 408 was at less boost to hit that number but i can't remember. might be able to do a search on it since i am sure i posted up.
#29
How do I change this text
you will need more than 119 MPH to clear 10.90
As EVERYONE has said the 4l60 WILL NOT HOLD.
