lower mounted turbos
Old Jan 11, 2009 | 03:00 PM
vanillagorilla's Avatar
Originally Posted by 1BADAZZSS
That is why there is a pressure hob switch that sets in front of the pump on the sts kits. If the pump stops working the oil pressure will build up in the oil feed line resulting kicking the hob switch on and putting power to your buzzard inside the cab letting you know the pump has stopped workin.
That's what I figured, but when the fuse blew, I had no alarm. If the alarm was hard wired to the battery (which I don't think it is) I would've heard it. Fortunatley for me, the oil backed and pushed past the seals, so when the fuse blew, I had burnt oil coming out of my tailpipe. I was able to shut it off and basically coast into work a quart low.
I don't know why the fuse blew. It never blew again after that, but I never left the house again without spare fuses and oil. Not my idea of a good time.
Old Jan 11, 2009 | 03:58 PM
southern_chevy's Avatar
Why dont they come up with a way to just kill the truck when the pump fails? Instead of a buzzer you could have it wired to the fuel pump or any other way to kill the truck? I could see this not being to good if you were hauling *** cause brakes and steering would suck but would save the motor. Just a thought.
Old Jan 11, 2009 | 04:46 PM
1BADAZZSS's Avatar
You could set it up with a cattleprod in the seat. When the pump stops workin you will get shocked in the rearend. So that you can hurry up and pull off the road and shut the truck off
Old Jan 11, 2009 | 04:47 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
In my case, the buzzer had failed as well. I was using my STS harness at the time.
Take my advice. Routinely jump that switch and test the buzzer.
Old Jan 11, 2009 | 08:20 PM
silver-mod-o's Avatar
Hunt&Fisherator
Like I said, all this BS can be avoided anyway just by mounting it higher.
Old Jan 11, 2009 | 08:35 PM
kbracing96's Avatar
He's turboing a vette, there's not a lot of room to work with,
Old Jan 11, 2009 | 08:41 PM
Hunt&Fisherator
Oops, I wasn't aware did I overlook that somewhere?
Old Jan 11, 2009 | 08:48 PM
kbracing96's Avatar
Not in this thread, but he's talked to me a couple times That's how I know ALL!
Old Jan 12, 2009 | 03:48 PM
1BADAZZSS's Avatar
There is a company that make self contained oil style turbos. Might be able to do something like that.
Old Jan 12, 2009 | 08:06 PM
Who is this you speak of? If you're refering to aerocharger, they've been out of business for years.
