Low on power?
Old Jan 17, 2017 | 07:42 PM
Razor's Avatar
BMF
Default Low on power?
Just dynoed my 6.0 at 22lbs boost, e85 , billet s480, 218/218 cam, 4" exhaust, 15 degrees timing and made 704 rwhp. This is through a 4l80e, ford 9 inch, and unlocked converter.
Seems low.... yay or nay?
Old Jan 17, 2017 | 07:46 PM
About20ninj45's Avatar
What gear was the pulls done in? I've seen 620whp @15 psi on e85 on 16 degrees of timing, i don't think your to far off tbh, but what do I know?
TrickTurbo's Avatar
Truck Sponsor
What Intercooler if any??
Do you have any other power numbers to share, what was it at 10-15-20psi?
Old Jan 17, 2017 | 07:48 PM
FFDP's Avatar
How rich was it?
Old Jan 17, 2017 | 07:55 PM
Razor's Avatar
BMF
Treadstone 1300 vertical flow intercooler.
Old Jan 17, 2017 | 07:56 PM
Razor's Avatar
BMF
10 psi was 520 ish..on e85
Old Jan 17, 2017 | 08:05 PM
TrickTurbo's Avatar
Truck Sponsor
what is that 1300? I do not see that number on their site?
Old Jan 17, 2017 | 08:07 PM
GMCtrk's Avatar
First off, I've never been a big proponent of dynos. I ran at the track, a lot.
My best educated guess is that your converter is turning into an oven.
I needed the absolute tightest converter CircleD could make in 258mm in order to hold 22 psi, and even then it was not as efficient as ideal.
If you have a converter designed for lock up under power, I would suggest doing that and re-dynoing. Or, log converter slip thru your datalogger if you can.
Old Jan 17, 2017 | 08:10 PM
Razor's Avatar
BMF
Trv259 intercooler from treadstone
Old Jan 17, 2017 | 08:28 PM
Razor's Avatar
BMF
Its a Pro yank single disk converter. Not going to lock this one up on the dyno.
I was just anticipating more rwhp as I made aroun 630 rwhp with a 2.3 whipple at ~14 pounds boost.
