Originally Posted by 95TwinTT
(Post 4275310)
I’m sure you could find a place for the spray nozzle, downstream from the MAF.
I have been using Meth for three years now and no sign of problems with the IAT. Just added alcohol to my Camaro this past year. It already had a liquid to air after cooler, but the alcohol allows me to get by with 92 octane instead of the race gas @ 15 psi boost. IAT relocate post meth nozzle? |
You also have a MAP sensor. That should compensate for density difference for the cooler air.
I don’t use a MAF sensor. To me the important battle is “pinging”. Pre ignition can do a lot of damage, not to mention sapping the power. On my after cooler, I added a temp sensor for the coolant. The system is perfect for cruising and running on the strip, but for road racing, it gets “heat soaked” in a short time. |
(Post 4275358)
I don’t use a MAF sensor. To me the important battle is “pinging”. Pre ignition can do a lot of damage, not to mention sapping the power. On my after cooler, I added a temp sensor for the coolant. The system is perfect for cruising and running on the strip, but for road racing, it gets “heat soaked” in a short time. Long story short, I am testing those two devices and would also be testing an AEM coolant gauge (0-5v AND serial output---dashdaq does 0-5v input AND serial!) as well...so I would 100% for sure have a water temp sensor in the coolant (IC) circuit...especially for datalogging as well. Interesting on the MAP, I will keep that in mind. Now--slightly changing gears, can the Trick Flow A/C circuit be used on N/a intake models? -Mike |
