Logging boost with efilive?
Old Sep 21, 2011 | 03:19 PM
sharpshooter's Avatar
Default Logging boost with efilive?
I currently run a 1 bar tune and I'm not looking to go SD.
That being said could I run a 2bar sensor with my current tune so I can log boost with efilive without changing anything but the sensor? If so what pid do you log?
Old Sep 21, 2011 | 03:28 PM
smokeshow's Avatar
Mod with training wheels
Yes you can. You just need to change the MAP linear calibration and offset for the new sensor. Not sure what PID, not an EFI Live user.
Old Sep 21, 2011 | 03:51 PM
lownslo's Avatar
i think the pid is listed at Manifold Absolute pressure MAP. I would have to go look and I don't have efi in front of me right now.
Old Sep 21, 2011 | 04:06 PM
JoeyGC5's Avatar
Parameter C6301, MAP sensor scaler. For 2 Barr sensor use value of 190, and for 3 Barr scaler use value of 288. Before swapping sensors connect to scanner and view value of MAP with engine off. After replacing sensor adjust scale value to give same reading with engine off.
Old Sep 21, 2011 | 04:12 PM
Superado's Avatar
11 Second Truck Club
tons of info:
EFILive Forum
http://forum.efilive.com/forumdispla...xide-%28N20%29
check w/ joecar if you have any questions...he's always been a big help
http://forum.efilive.com/member.php?10-joecar
Old Sep 22, 2011 | 12:49 AM
02'Z71ONDUBZ''s Avatar
Just log your MAP pressure in kpa... the cobalt ss 2-bar map is a direct swap.
chopperloco
Sep 28, 2015 08:40 AM
2500ZL1
Sep 12, 2015 03:50 PM
creekrat
Sep 10, 2015 12:59 AM
Boyes50
Sep 8, 2015 12:06 PM
06murder
Sep 4, 2015 03:54 PM
