livernois kit
Old Feb 26, 2006 | 11:13 AM
  #21
turbosilveradoss's Avatar
I have one of their kits on a SSS and I love it!! Any questions fire away..
Old Feb 26, 2006 | 11:36 AM
  #22
how are the boost characteristics around town and on the highway? What kind of boost do you run at @75mph on the highway? How long did it take to install the kit? Was tuning easy?
Old Feb 26, 2006 | 12:07 PM
  #23
greentahoe's Avatar
Originally Posted by Snake Eater
so how do you like the turbo over the SC? how is boost around town and on the highway differ? I know how my blazer builds boost but its way too big and has exhaust leaks. I wish I knew someone near me that had a turbo so I could ride along.
What kind of boost do you run on the highway at 75 or so?
Wont know for a couple more weeks. Im putting the new motor and turbo on in the next couple of weeks and then dropping it off for the 4L80 to be installed. I'll definately post up about the differences though. The new setup will have a 3200 PI as opposed to the 3000 that I have now.
Old Feb 26, 2006 | 03:15 PM
  #24
EDawg's Avatar
is the meth a must? any problems you ran into rught after install?
Old Feb 26, 2006 | 04:07 PM
  #25
The kit was pretty striaght forward to install everything other than having to fab a a/c hose it was complete. As for the boost at 75 mph I guess 4-5 lbs at steady cruise. I boost to 9lbs with no meth on the low boost setting and 14-16 lbs on the high boost side with a stock bottom end with no kr for what it is worth and after we got the tune right the only thing that has been a problem is keeping a tranny together..... 4 times a charm I guess The kit rocks I have friends with sts 76mm kit on 2wd trucks and from a roll or a dig I rip them This year I have bigger plans if I get the tranny to stay together with a 125 shot as well as a bigger turbo but It will g-tech 12.3's right now at 6800 ft today(corrected) not bad for 6230 lbs.
Old Feb 26, 2006 | 04:10 PM
  #26
Oh and for around town driving anthing about 15 mph boost is almost electric pulls hard *** hell
Old Feb 26, 2006 | 04:15 PM
  #27
IDISAPR's Avatar
Thanks.
Old Feb 26, 2006 | 04:18 PM
  #28
quicksilverado's Avatar
Your at 4-5 lbs of boost while cruising at 75. Something is not right. At 75 I never see boost unless I am on a steep grade then I see 1-2 psi at most. How much boost are the sts kits running?
Old Feb 26, 2006 | 04:21 PM
  #29
You could always spend $380 and swap in a D-max IC. They are HUGE!
The Duramax I/C is to big. There is not enough room without some serious hacking to make it fit.
  #30
awsome, thanks for the info. I should find out tomorrow how much I'm getting for my silverado and the kit will soon after be on order. I wonder if I would still need meth if I ran the bigger D-max IC. I guess we'll see
