Lifter fail = valve train upgrade including Trip 12
Old Jul 17, 2015 | 10:04 PM
JordanH's Avatar
Restricted
Originally Posted by MattOKC
Wow, those are some great numbers.
Thanks for the help.
Thanks! With the cam and springs, plus the AFM/DOD and VVT your doing now, your truck is going to be a totally different vehicle when you're done and get it re-tuned! Your for sure gonna be in the 500+ range on HP and TQ, and that 6l80 you have is pretty tough! If you like it now, you're gonna love it when you get thru with the current mod list!
Old Jul 20, 2015 | 07:23 PM
LaCheyenne's Avatar
JordanH what injectors are you running? Are you on e85 already?
Old Jul 20, 2015 | 09:47 PM
JordanH's Avatar
Restricted
I'm running 60lb @ 3bar Bosch ev14 injectors. No e-85... Initially I was going to run it, but there's only 1 gas station around here that sells it... And I drive the truck to southeast Texas and Birmingham a bunch.... So I stuck with the 91, it's the highest grade fuel out here in west Texas.
Old Jul 20, 2015 | 10:15 PM
George C....'s Avatar
Formerly ScreamingL
The FF pump will get ya around mid 500s on 93 before pressure starts to drop off
Shouldn't need alot of boost from a turbo setup to make 500, my blower setup makes 540 on 12 psi
Old Aug 5, 2015 | 08:57 PM
JordanH's Avatar
Restricted
Any updates on this?
Old Aug 5, 2015 | 10:15 PM
GMCtrk's Avatar
Don't you have TFS heads?
Old Aug 6, 2015 | 12:07 PM
MattOKC's Avatar
Not sure what TFS heads are. They are stock heads for the LC9. As for an update, I stared the swap. I have it stripped down, but I'm having trouble getting the crank pulley off. I'm using a 3 jaw pulley puller. I fought it 4 hours last night. Every time I start to crank on it the jaws come unseated. I'll be researching today. As for the FF pump, UPS should be delivering my Walbro 450 today.
Old Aug 6, 2015 | 12:45 PM
MattOKC's Avatar
I guess the Chrysler model puller works perfectly I'll try it tonight
Old Aug 10, 2015 | 08:34 PM
darnie's Avatar
I'm running 91 hit 600/656 @ 12.5 psi
Old Aug 11, 2015 | 10:13 AM
MattOKC's Avatar
Good to know that it can be done. I got it all back together and I'll be taking it for new tune Monday. I'll post the results
